What is the difference between billet and OEM?
Amsoil 3000 not Recomended
Shop recommendations in So. Calif. ??
Hi guys, a stupid question. What is the difference between billet pcs and OEM? I am sending my 06 48RE auto in for upgrades and I am hearing that Billet pcs are a must while it is open. I do not beat the truck but I do plow my driveway with it. I have an Edge w/att in it and about 45K on the truck. I already have decided on a TC, VB and gov Sol, but am not sure what you guys mean by billet. Is is the type of material used to make the pieces or something else?
Any help is appreciated.
Thanks
"Billet steel" parts are machined from solid steel castings, not stamped steel. The advantage is strength, durability, and reliability. If you don't tow heavy trailers you probably dont' really need the higher cost of billet components.
Depends on what billet pieces you are referring to. They is billet steel, billet aluminum, billet servos, billet shafts, etc. If your building a trans with more pressures you will need some billet pieces. If you are using a triple disk TC a billet input is almost a given.
Billet stuff
Hi guys, sorry should have been more specific. Billet accumulator, servo. band, band support basically parts that can be changed out or upgraded with the VB out. I really want a solid long life 48RE and want to beef it up in the weak areas. I am just trying to do this right the first time, and not have to go back after something I overlooked or did not know about later
Any suggestions are appreciated.
Thanks Again.
Harvey is just a little off... . the term billet usually refers to a sold piece of metal the way it comes from the mill... . solid steel, solid aluminum or other allow... . a head or block would start as a solid piece of steel or aluminum and the machining center would carve out the part... . The normal method would be to either sand cast or lost wax cast the part, thus a much less expensive way... and the part is than machined...
A cast part machined is made at a fraction of the cost as a billet piece of goods... . most airplane parts are from billet material where they might machine away 70% of the base metal... a brake rotor on a truck might start as 50 lb chunk of steel before it becomes a rotor were a cast rotor might start as a 22 lb piece and end up as a 20 lb part.....
Almost all aluminum parts, either cast or billet go through a process called vacuum impregnation... this process assures there are no leaks... mag wheels, cylinder heads, water pumps, thermostat housings, etc. etc... . its at least a page to explain vacuum impregnation but almost all aluminum that holds pressure or has a liquid against it has this process... where only some cast iron parts have this process done...
