On the later 1st gens, heavier springs were available with towing packages, and redesigned spring packs, as customer complaints about sagging were beginning to filter up about the 3/4 tons. The 6" block was standard on all 4x4 models that I've seen. Towing package springs had more leaves, with a large overload spring on the bottom. The front springs had thicker leaves, as well. If you want the truck to ride better and sit higher, I'd suggest a new set of springs from Skyjacker. They're usually somewhat reasonable, and by the time you take your springs down, have them rebushed, rearched, and add a leaf or two, you're going to spend close to the same money in the end. I can't find the part number for their 2. 5" kit, but I think it was just under $1,000 for the springs, u bolts, etc. It's been two years since I bought one. If you just want to keep your springs, consult with your local spring shop, and they should be able to suggest what you need. Just my opinion. Good luck!
God bless,
Casey
