Brian, actually I do have -6 between the filter and the VP, but TT is correct, you can get the fittings from -8 to the VP at ADT.
The only reason I didn't use -8 between the filter and the VP is that I didnt really see the point, since the filter and VP ports are smaller than the -6 already.
Even if you drilled out the VP port, there is still no benifit IMO. Once the fuel enters the VP there is a small cavity (never meassured it, but I'm guessing it's about 1-2 tablespoons in size) and then another 1/4"ish port.
I also fabbed my own bracket, and is mounted by the tank on the outside of the frame.
Rob
