There has been a noise I quite can't figure out what it is. I have a feeling it could turn serious? It usaually does it in 5th gear and 60 mph or higher. Its definatly noticeable at wot.
It is also triggerd by bumps in the road too. But its kinda faint.
The sound is coming from the front.
It sounds like it a sporatic tapping or tweaking noise.
The motor runs fine. The tranmission shifts fine. The 4x4 works fine.
I don't think its the lift pump. It only does it in 5th gear. The motor roars too loud to hear it if its doing it in 4th gear?
I'm begining to think it a bearing in the clutch, transmission or transfercase. Or possible loose mount between the motor and tranfercase.
Its been doing this for several years now.
