Engine/Transmission (1998.5 - 2002) What is Turbo bark? What Turbo Do I Have? THE Holset thread
2nd Gen Non-Engine/Transmission rear bench removal
Just for those who were wondering. There have been a rash of posts lately on turbos and this just may help. The below list covers the HOLSET Turbos only.
As of Sunday August 21st '05 I have updated all the links so they work AND added the Forums section to browse too. The HOLSET SITEMAP Will give you everything, Below are the common links ... Enjoy :cool:
<hr>
A data plate is fitted to the compressor housing of your turbocharger. The information on this data plate must be quoted for service and parts support.
(A) Assembly or Part Number
Holset Part/Assembly Number for the turbocharger is the number quoted in all Holset publications and is the most useful number for service purposes.
(B) Serial Number
Holset Serial Number is unique to your turbocharger. This number can be used to identify which turbo you have although it will be a longer process than if quoting (A).
(C) Customer Part Number
Customer Part Number is the number given to the turbocharger by the engine manufacturer. This number will be quoted in all the engine manufacturers' literature. There may be more than one Customer Part Number for each Holset Part Number (A).
(D) Turbocharger Type
Turbocharger Type describes the model or frame size of your Holset Turbocharger.
HX-20-25-27 Specs
HX20-25-27
Developed in conjunction with our alliance partners MHI, the HX20, HX25 and HX27 are suitable for engines of up to 4 litres capacity.
Lightweight and compact, these turbochargers are aimed at light duty commercial engine applications.
Available with a wastegate turbine and low inertia rotors, these turbos are ideal for stop/start duty cycles on larger passenger vehicles and smaller commercial applications.
Standard Features
Choice of turbine housing materials to cover a wide range of temperatures.
Compressor and turbine wheels selected for optimum airflow, efficiency and pressure ratio.
Fully-floating twin hydrodynamic journal bearings.
High efficiency compressors with broad operating ranges.
Single entry turbine housings.
Superback compressor wheels for extended life and durability at high turbo speeds.
Optional Features
Watercooled bearing housings.
HX20 HX25-27
For Engine Capacity (litres) Up to 4 Up to 4
Output Range (hp) 50-80 70-180
Airflow (kg/s) 0. 2 0. 23
DIMENSIONS:
Length (mm) 176 254
Width (mm) 160 226
Height (mm) 130 148
Smallest Mass (kg) 2. 8 4
Largest Mass (kg) 2. 8 5
OPTIONS:
Wastegate
Watercooled B/H or T/H B/H B/H
MFS Impeller
HX-35 Specs
HX35
Designed primarily for 6 cylinder engines of 5. 0 to 6. 5 litre capacity, the HX35 turbocharger has higher flow aerodynamics capable of providing up to 0. 46 kg/s at 3. 0:1 pressure ratio.
A number of compressor and turbine options are available all featuring excellent map width, pressure ratio and efficiency.
Enhanced durability compressors are available.
Standard Features
Fully adjustable compressor and turbine housing orientation.
High pressure ratio capability.
Symmetrical twin flow turbine housings.
Variety of compressor and turbine housing flanges available. .
Optional Features
CNG Engine version.
MWE (Map Width Enhancement)compressor inlet.
Sound suppression baffles.
HX35
For Engine Capacity (litres) 5. 0 - 6. 5
Output Range (hp) 100-280
Airflow (kg/s) 0. 46
DIMENSIONS:
Length (mm) 224
Width (mm) 250
Height (mm) 169
Smallest Mass (kg) 9
Largest Mass (kg) 11
OPTIONS:
Wastegate
Ti Impeller
MFS Impeller
CNG Version
HX-40 Specs
HX40
Developed for 7 to 10 litre engines operating in the medium/light heavy automotive sector this turbocharger has many of the features found in the Holset heavy-duty range of products.
Generously sized bearings with watercooled housing options for applications with highly cyclic operations support a recently upgraded set of aerodynamic components.
Popular in a wide range of automotive and bus applications the HX40 is widely used in European and North American applications.
Standard Features
Optional Features
High durability impellers available.
Command valve boost control.
MWE (Map Width Enhancement) compressor inlet.
EWM (Exhaust Waste Management) turbine exducer.
HX40
For Engine Capacity (litres) 7 - 10
Output Range (hp) 175-350
Airflow (kg/s) 0. 53
DIMENSIONS:
Length (mm) 231
Width (mm) 250
Height (mm) 169
Smallest Mass (kg) 11
Largest Mass (kg) 14
OPTIONS:
VGT
Wastegate
Ti Impeller
MFS Impeller
HX-50-55 Specs
HX50-55
For engines of 10 to 15 litres capacity the HX50 and HX55 are specified on some of the world 's premium rated heavy-duty engines at up to 500 hp.
The HX55 has a deserved reputation for industry leading performance in this segment.
Recently upgraded with new compressor options the HX50 and HX55 compressor demonstrates excellent characteristics of map width, pressure ratio and efficiency.
Standard Features
Selected compressor and turbines for optimal airflow, efficiency, pressure ratio and transient performance.
Symmetrical twin flow and single entry turbine housings.
Optional Features
CNG Engine version.
Watercooled turbine housings.
Low flow turbine stage.
HX50 HX55
For Engine Capacity (litres) 10 - 15 10 - 15
Output Range (hp) 295-500 295-500
Airflow (kg/s) 0. 75 0. 75
DIMENSIONS:
Length (mm) 249 259
Width (mm) 275 275
Height (mm) 225 225
Smallest Mass (kg) 16 18
Largest Mass (kg) 19 21
OPTIONS:
VGT
Wastegate
Watercooled B/H or T/H T/H T/H
Ti Impeller
MFS Impeller
CNG Version
HX-60 Specs
HX60
Suitable for engines of 14 to 16 litres the HX60 has been designed for I6 and V8 engines of up to 600 hp output (up to 0. 95 kg/s).
Well proven on some of the top power European and North American automotive applications, the HX60 is the preferred choice for specialist power engines.
Available with wide map high pressure ratio compressors, the HX60 can also be specified with the Holset heavy duty boost control wastegate.
Standard Features
Optional Features
CNG Engine version.
HX60
For Engine Capacity (litres) 14 - 16
Output Range (hp) 320-600
Airflow (kg/s) 0. 95
DIMENSIONS:
Length (mm) 280
Width (mm) 285
Height (mm) 237
Smallest Mass (kg) 18
Largest Mass (kg) 22
OPTIONS:
Wastegate
Watercooled B/H or T/H T/H & B/H
Ti Impeller
MFS Impeller
CNG Version
HX-82-83 Specs
HX82-83
Designed for high power density industrial, power generation and marine applications, the HX82 and HX83 turbochargers are suitable for engines of 15 to 25 litres or 1200 hp per turbocharger. Multiple units can be configured for engines of larger capacity.
These well proven turbochargers have had the benefit of continual development through many years of field service on some of the toughest applications imaginable.
Standard Features
Optional Features
Titanium impeller for high pressure ratio capability.
HX82/83
For Engine Capacity (litres) 15 - 25
Output Range (hp) 500-1200
Airflow (kg/s) 1. 5
DIMENSIONS:
Length (mm) 332
Width (mm) 318
Height (mm) 300
Smallest Mass (kg) 32
Largest Mass (kg) 50
OPTIONS:
Ti Impeller
MFS Impeller
