When I had a F450, it had a 6 spd manual transmission that would outlast the truck and motor (wish I never sold that rig). Hence, I rarely worried about leting the transmission do the work. Now that I am driving a Cummins mated to an Automatic (99 2500 with the auto trans), I am trying to determine how best to manage the workload. There are times you turn the O/D off and let the motor do the work... other times I am told it is OK to let the trans do the work and run the motor at a lower RPM. Chirs at Relentless Diesel tells me to keep the RPM above 1700. If I have to go below 1700, then I should turn O/D off. He knows his stuff so I am following his advice. However, I have noted w many owners commenting about how they turn off their O/D everytime they tow heavy.
So what technique do you use? When is it OK to to in O/D and when not?
I tow a 11,000 lb boat. If I am on a longer trip, the load on the trailer can be as high as 15,000 lb.
