What is your fuel pressure 1. at idle and 2. floored
Front Stabilizer (swaybar) end links
12v or 24v...help me decide
Before and After
Before new lift pump 9 idle 4 WOT :mad: After 16 idle 12 WOT :D
I even got the 5 screw stealer to do it under warranty with no arguments. :eek:
Mine is 16psi idle and 8 0r 9 psi I think at WOT. Never get enough straight road to stay on it very long though with the EZ on it. :D
Mine is 16+ at idle and 11 full throttle.
Stock 02 auto
I wish the warrantee was expired so I could start bombing!. It already has 2500 miles.
fox
12 psi @idle, 6-8 psi pulling hills. This is Post Filter so no panic, but I'm watching for deterioration as 30k miles is coming up and mods are planned in summer:D Jim G.
im still learning here so there is two differnt readings ? mine comes of the bottom of my filter . i have 13 @ idle 11 @ crusie 8 @ wot. are these good numbers. im getting my truck inspected on wedsday . should i point this out. is it time for a new lift pump?
16. 5 PSI at idle. 16. 5 PSI at 110 MPH uphill @ 32 PSI boost. BTW, one lift pump mounted on the frame, near the tank with a pre filter.
STOCK @ 39,000 miles
Post-filter
..... 11 psi @ idle
..... 9 psi @ 70 cruising
..... 6-7 psi @ WOT
Calling to make appt. with dealer Monday! :(
