I was checking fluid levels under the hood today and noticed that the coolant reservoir level is at the ADD mark. The owners manual says to use an ethylene glycol based coolant. The first thing that comes to my mind is Prestone, a coolant that I have used in my MBZ 300SD Turbodiesel with no problems.
I know that diesels can have problems with cavitation. I guess the question is this. Are you guys using any special type of coolant made specifically for a diesel? Lastly, are you adding regular tap water or distilled water?
Thanks
CJ in RSM, CA
2001 Dodge Ram 2500 SLT Quad Cab, 6spd,ETH,4x2,4. 10 Limited Slip, Trailer tow hitch, long bed
Thanks
CJ in RSM, CA
