what kind of pusher pump do I need?
Air Conditioning and Fan Clutch
Boost,Trans Temp, and EGT gauge question
I am wanting to get some advice on what kind of pusher pump I need for my 03 doge automatic :-{} I have 2 chips stacked right now but I am wanting to get good injectors and turbo as well,what kind of pusher pump,turbo and injectors would yall recommend,wanting some injectors that dont smoke a whole lot, :{ also my edge attitude HOT juice for 03 to 04. 5 is for sale $725 overhead pod with it. let me know
From what I understand you don't need a pusher pump. I changed my lift pump to a pusher pump because the stock pumps were failing under warranty and they are replacing them with an in-tank pump. I just don't want to drop my tank to change the second pump when it goes out. So I purchased the diesel dynamic pusher pump. It's a carter pump and it comes as a kit with all the fittings you need to convert to a pusher pump. The key is to install the pump as close and as low to the fuel tank. Your CP3 pump doesn't need high pressure or volume. It creates the needed pressure and volume of fuel for your injectors.
Fill out your signature so we know what mods you already have. It all depends on how much power your going for. Since you have two chips, I would upgrade your transmission first if you aready havn't. Can't use all these fun mods if your transmission can't hold it. Then I would go with either Ind. Injections or Don M injectors and Ind Injections sps 62 turbo. As for a pusher pump, go with a FASS 150, your wont regret doing so.
Deffentily the FASS, my friend has two 01 CTD and they both have the FASS and its great. I will soon have one also! Oo.
The FASS was one of the best mods I have done to my truck...
As far as picking a pump, research it and make a decision from that (there are a bunch of threads discussing it)... you have a lot of choices out there... including some belt-drive mechanicals that are proving to be potentially better than the FASS...
steved
My Fuel system from Glacier Diesel Power works Great! Just installed the 2 micron filter setup that goes under the intake horn. Super easy, SUPER QUIET.
I have the edge hot juice, stacked with the PPE,DTT transmission,AFE filter, 4 inch MBRP exhaust,3 pod gauges,wanting some good injectors,and turbo
I just got mine today, The GL392 plus the 2-micron kit...
At 600hp, I will be very happy if this little sucker keeps up. And if its quiet
Thats not entirely true, they don`t necessarily need alot of pressure, but they do need plenty of volume. Lack of volume is what will kill the injection pump.
