Lag with 89, 91, 93%
Kevin, while I haven't driven the 93%, I have an 89%, and have driven the 91%.
And of course, I've driven the stock version, about a 70%
I'll attempt to explain how I think about turbo lag. With the stock TC, when I mashed the throttle from a standstill, the RPM went up to about 2000, and of course the fueling went up to start creating more power and more RPM. It is the volume of hot, expanding air thet is forced through the turbo while the air is still expanding that causes the turbo to spin. The greater the volume and pressure, the quicker and faster the turbos spins up.
So, when floor the throttle with a stock TC, the rpm goes up to 2000, there is a lot more hot air coming through the exhaust manifold and turbe at this rpm than with the 89% TC.
When I floor the throttle with 89% TC, the engine can only rev to about 1400 RPM, and there is a lot less hot expanding air going through the turbo trying to spin it up. Therefore it takes a second or two longer to get an effective amount of turbo rpm. [eg. Boost]
With an even tighter TC like a 93%, the rpm when the throttle is floored from a stand still will be lower yet, causing more time to get the turbo spinning.
When you add a load, or tall tires, the effect is worse, because it takes more power to get the truck moving, which allows the engine rpm to climb, which generates more hot air for the turbo etc. etc.
So with the original factory TC, I had virtually no lag, the turbo had plenty of hot air to spin it up quickly, with the 89% I have a slight lag, and it is so slight that I have to pay attention or try to create lag to notice it.
Slight throttle with brakes still applied, about 950-1000 rpm eliminates any lag. Any more RPM with brakes applied results in leaving rubber on the pavement!
With a tighter TC, with more lag, I'm sure it would/could be annoying.
With 4. 10 gears, it might be less noticeable.
Clear as mud, right??
I hope this helped, Greg L
