Engine/Transmission (1994 - 1998) what mods next????
2nd Gen Non-Engine/Transmission Brake Bleeder Screws
well as you can see i have a #5 plate, laser cut dv's, 3k springs, 370s, and am in the process of building a 35/3b twin setup. my question is what order do you think i should go from here??? i plan to get a south bend dd clutch in the spring to hold it all. i cant afford it to have it blow up so im turning to you guys for some input. my thoughts were to get the head o-ringed, get a 0 plate and vallet switch, and a local injection shop said sompthing about modifying the injectors to like a 450hp injector or sompthing by replacing some of the tips and internals. i am also having a pump built by them. i want to end up with water/meth and nos so this is why i want some input so i dont make a bad mistake and put the truck out of comission.
if it were me i would fire ring or o ring the head and do a new gasket and stud kit to hold the boost of twins..... with that much fuel you will need a lot of boost to burn it so dont forget to keep the hat on it all ;)
yes i do very badly need to get that done. but i cant find a shop close to me to do it and i dont want to send it half way across the country because shipping would have to be crazy on somepthing like that so ive been just looking around and found some shops that said they might try it but have never done it so it makes me a little leary. i remember talking to someone in mi that said he would be able to do it but lost the number.
