bmoeller said:What a question.People like you make it hard for others, who don't lie, to get work done under warranty. Whether a mod caused a problem for them or not. Even if a truck was stock and only had gauges.
Wanna play, you got to pay.
I am my own warranty station.
MMead said:"It's not lying if they don't ask" ?????
Wow.
How is this any different than any other form of theft? People are taking something they did not pay for. If you take parts and labor from Dodge after a modification causes a problem and you do not pay for those parts and labor then you are stealing. It doesn't matter if they ask or don't ask, everyone here knows deep down that this is theft.
It's my hard earned money that goes to pay for damaged modified engines. Thanks, and good luck hiding those modifications.
Cummins Cowboy said:Everyone quit with the sob stories of morality, I think its clear and been documented quite often I might add on here that DC uses the mod excuse to void peoples warranty just because they did a mod on the truck with no proof that mod caused the issue, I think all of us would just like to be delt with fairly, this is becoming less of a practice with DC. the man just asked which mods can't be seen by the dealer, he didn't ask for a lesson on right or wrong, maybe he is just curious and wants to know for himself. who knows but the fact remains its not our job to teach the guy right from wrong
Diesel Power said:not true, i saw a regional manager use the drb with a special code and reveal every type of fueling the truck has ever seen, and how long it was in use. the average " diesel tech" may not see it but someone paid to void warranty's will. just a heads up
Diesel Power said:yes that is correct 04' or 05' warranty was voided with a smarty! he had it back to stock and everything, dodge engineers are not stupid, i just want that code so i can see all that stuff and alter it.![]()
2) No trace is left in the ECM!
I herby CLAIM that SmartyCR is the FIRST AND ONLY downloader that does not erase any of the stored data in the ECM. Smarty does NOT leave any footprints. Smarty does NOT set ANY codes once the ECM is set back to stock
DPKetchum said:Quad(owner of QUAD fueling boxes) answered this question on another forum. He stated that fueling boxes CANNOT be detected and gave a LONG reason why. About how they DON"T alter the ECM just the signal coming to certain sensors down the line from the ECM in a nut shell. Once you read how it all works you can understand. DOWNLOADERS ALTER the ECM. Fueling boxes do not. Signal coming from it are the same as stock. Its just that certain sensor parameters are changed after the fact. A down loader changes the signal at the source.
Diesel Power said:the voided waranty i was talking about in other posts was loaded with several other performance mods, so the smarty may not have had anything to do with it.![]()
