Engine/Transmission (1998.5 - 2002) what next
Engine/Transmission (1994 - 1998) OH NO-Puddle of oil under my truck
Engine/Transmission (1998.5 - 2002) propane??
i have a 98. 5 with 275 injectors 4inch exhaust turbo back straight piped edge comp pump wire taped and afe airfilter 5 speed with south bend clutch i would like to go with biger injectors and a hybrid turbo i pull between 5,000 and 15,000 pounds what turbo and injectors do you thing i should go with
Maybe a set of EDM mach 1. 5's and a hybrid turbo (HX-35/40). I tow a lot and would not want to have much lag or heat. I have a ton of power now, and I push right at 35psi out of my stock turbo. You could go with the injectors, then just leave your comp on a very low setting when you tow, until you get a larger turbo. I would like my truck to run slightly cooler, so a hybrid turbo is in my near future. BTW, I can't top 1250 on the pyro even towing heavy.
