unless you are someone who is anal about monitoring every system, i wouldn't worry about the lube oil pressures. however, if you do end up monitoring it, you can start to track trends in lower than normal lube oil pressure. once you start to know what is normal for your engine, you will see slight changes based on the condition of the oil. . if you start to get fuel dilution, you will see it drop and you could catch it before any damage is done [first thing that will go toast it turbo bearings, but it is an easy external component to change]
i am quite anal about monitoring my engines. .
