JH8128 said:I would use AMSOIL product# FGR01 75W-90 Synthetic Long Life Gear Lube. Hope this helps.
Snoxracer said:I am going to be placing an order for synthetic oil, and was wondering what the transfer case uses. I know people recommend 75w-90 for the Diffs, syn ATF for the trans, but not sure what my truck takes in the transfer case?
Thanks
Snoxracer
NGM Diesel said:you can also use the amsoil 5w-30 syncromesh, it's what we reccomend for the t-case. it has better HD performance under big HP.
.fj40dave said:How about the NV5600 transmission..... recomendation there?
Ok... . diff's tooWhat do you suggest for the AAM 9 1/4 front and 11 1/2 rear with limited slip?
Dave
fj40dave said:I'm researching which fluid to use in my NV271, and see that ATF is recomended.
You suggest the AMSOIL 5-30 syncromesh which (if I'm reading this right) is a "manual syncromesh transmission fluid".
Is it ok to use the manual fluid in the NV271 although the ATF is called for..... or..... I guess what I'm asking is: When the manufacturer calls for the ATF and you recomend the manual, what makes the manual fluid a better choice.
I'm wanting to change/add the best stuff I can.
Dave
Diesel Thunder said:On the transfer case, do ya'll fill it until it runs out of the fill hole with ATF+4?
Snoxracer said:How much fluid will the diffs hold now with Mag-hytec covers installed? Both front and rear? I hope that 12 quarts is enough because that is all I ordered. I ended up going with 75-110 amsoil severe gear, I thought that it would be a happy medium over 75-90 or 75-140. Anyway thanks again!
Snoxracer
Snoxracer
