What other power steering fluid can we use
Wife put my '06 key through the wash........
Superdawg
Steering seems to need a little more effort than I think it should.
Has ATF+4 now, relatively new fluid. Would changing to a different fluid such as Royal Purple, Amsoil, etc. make the steering easier?
I searched this site for power steering fluid alternatives but I can't find them. I know I have seen them somewhere. If someone could post the link that would be great. 2004. 5 4wd
thanks
I used Royal purple ATF in my last truck and this one will get it as soon as I get around to changing it, did help and doesnt foam up and cavitate the pump off road like the factory fluid does. I believe Checkers/Kragen/O'Rilley/Shucks now has Royal Purple at decent price
When the steering effort gets high in the 3rd gens it is usually the gear box that is failing. A good synthetic fluid can extend system life as well as flushing the system at regular intervals when used hard
Thanks for the replies.
Tires-stock Michelins, good condition, wearing pretty flat.
Has Carli ball joints x4-not sticking.
Redhead steering box-Just adjusted. No play, not tight.
Has 08 upgrade but is 2 yrs old. Just replaced the drag link due to two bad ends.
Tie rod ends are tight, tighter than I would like. Seems to have a bit of memory steer. On a flat/rough road, it seems to head off right or left. When driving on a crowned road, it will drift in that direction. Smooth flat road-drives straight.
Alignment- Left 4. 8 castor
Right 4. 9 castor
toe in 1/8"
Track bar-many problems. To make that story short, I replaced it with the Carli track bar. Heim joint at axle and Delrin bushing at frame. Frame connection drilled out to 5/8 bolt. FINALLY, no more track bar movement.
The best I could describe it, tight tie rod ends would be a perfect suspect. Most people tell me the steering box should more than compensate for those.
