Engine/Transmission (1998.5 - 2002) What Parameters to Monitor
I have an EGT/Boost guage. I am going to install a fuel pressure guage. What other parameters do I need to monitor. Specifically temperature ? Rear differential, transmission, transfer case ?
I have the mag-hytec rear diff cover.
I tow fairly frequently being at about 17k gross.
Thanks
Dennis
transmission temp, and that should be about it. The mag hytec will help the diff, you should also look into getting a double deep transmission pan. The fuel pressure gauge should be top priority!!
