Engine/Transmission (1998.5 - 2002) what programmer/most performance
Engine/Transmission (1994 - 1998) Torque Converter...???
Engine/Transmission (1998.5 - 2002) couple auto ??'s
I want to buy a new programmer for my truck,can you guys steer me in the right direction for the most performance?I bought the superchips 4 years ago,and I think it is just ok. I have gauges,4"exhaust,walbro fuel pump w/upgaded lines. I also want to upgade my clucth-any suggestions on the clucth will be helpful to. I did some research and came up with some picks-edge juice w/attitude? - smartty stacked w/tst? any others you guys think are good?What are you the most impressed with? THANKS
I love my drag comp stacked with smarty, but is seems like you can't go wrong with the tst smarty stack either. In the long run im sure youll be perfectly satisfied with either. In fact i think someone posted a dyno number comparison with a bunch of different chips/stacks and the edge and tst were within 7h. p. of each other? i may be wrong
hope this helps
I am very happy with my edge drag comp/smarty stack. I never ran my TSTcomp with the smarty, but it was very violent when going from on power to off. I changed to the comp and then later got the smarty. I am extremely happy with not only the power but the driveability of my current set up. I run SW #6 fwiw and very rarely even turn on the comp. with the mach 4. 5s i dont really need it that often. Oh yeah, clutch ... Southbend all the way.
im really impressed with my drag comp/smarty stack i keep it on sw8 and comp on 5x4... as far as a clutch goes, go with a south bend. also look at what your ultimate goal is and dont go cheap on the clutch i only did a con fe and now im replacin it with a double disk cuz im goin to start sled pullin and it will slip like crazy if i power brake it... just my 2cents
i have seen great results from the smarty/tst stack.
as for the clutch as stated above southbend all the way. no doubt in my mind. also like stated above decide you ultimite goal and buy a clutch for that. that way you only have to do it once. i wish i would have taken my own advice. :{
