Engine/Transmission (1994 - 1998) What pump???
2nd Gen Non-Engine/Transmission wiring brake controller
what forum is this???
just joking. of course it is a 12 v. what makes the difference in the hp in the auto motors vs the manual trans motors. I have a 1996 with a manual. I am going to put the 1998 motor in the truck. Is the long block the same as my 96??? sorry so many questions. justin
The manual pumps have 215hp injectors if you remove the injectors from the manual motor and put them on the new motor you should be good to go. Also, the harmonic balancer is larger on the 215hp motor so you may want to switch that as well.
