If you installed a set of 300 HP or 370 HP in your engine, most likely (you will) you would get a low speed skip/miss/stumble. It might even shake the truck. It has more to do with the delivery valves are too small to fill the injectors at low speeds on the smaller pumps.
You could install a set of Bosch High Flow delivery valves (about $250-300) and try the larger injectors. They may be OK , may NOT.
You`ll probably notice the "skip" with the 215 HP injectors. I do.
The best approach is to pull the pump and have it calibrated & set up. 400 HP & 4000 RPM`s are possible and anything in between. Piers @ BD Engine Brake can do this. It could get expensive though.
Bill R
94 2500 SLT 4x4 5 Speed, 3. 54 LS, JRE 4" exhaust, Autometer Pyro, Boost & Water temp gauges, Bosch 215 HP injectors, Timing @ 14. 7 º, JRE Stage III #4 plate 270/675, AFC spring kit, Scotty Air, Bully Dog Propane Injection, Roadmaster Active Suspension, Optima Red Tops, Geno`s Exhaust Blanket,Espar Heater (won it!), Synthetic lubes throughout.
[This message has been edited by HEMI®Dart (edited 11-03-2000). ]
