What shocks to replace OE?
traded my Duramax for a Cummins!
Lift pump question
I have been less than satisfied with the performance of my OE shocks. They don't seem to be up to the task of handling such a heavy vehicle. If anyone else has had this problem I would like to know what was done to correct the problem. Thank you in advance.
I switched to those adjustable Ranchos and used them for 4 or 5 years. I put on a set of Bilsteins , but I think the Ranchos rode a little better.
If you do a search you will find that the majority of CTD owners are installing Bilsteins. Even owners that have previously had Rancho's feel the Bilsteins are higher quality and give a firmer ride. I would suggest you put the Bilsteins on the front and the adjustable Rancho's on the rear. That way you can customize your ride when you are towing or hauling and when you are not the rear shocks don't take that much abuse unloaded.
