93 theres more
rear axle seals leak needs shim
emer brake cable needs to be wire tired at shoes
water leaks in cab
steering shaft check
if 92 or 93 better cooling system
91's had poor rad design
back brakes need adjing every 3 months
check drivers and pass door hinges for
cracks at door bolts small but there are there
may need to weld.
power steering leaks check
brake vacuum booster may be bad
check if emer brake and abs ligs are hooked up
then chk to see if lights stay on- could be booster or abs ,
check for frame cracks p. s box and under bed
drive and chk for shimmy while under light braking
may need steering stablizer, also frt rotors
may need turning ,chk for brake pedal polsates
and if rear brake lock up .
over all a great truck , ive had mine 3 years
and 50 k also if 5 spd getrag
it will need to be replaced soon,chk 4 rebuild tags on it, chk rear end ratio best 3. 54
also see if factory overlAODS SPRINGS,
thats it bill
