What should I watch for with the guages
ECM re-Flash
Auxillary Lighting
I have the SPA guages that have the LED warning lights for each guage. The warning levels can be set to a value to let me know that I should do somthing to decrease the values when the LED goes on. I need to set the high warning values for Boost, EGT, Trans Temp and Pressure. What should I set them for?
Thanks
Set the EGT at 1250, and Boost at 20 make sure the thr setting is at 1000. Can't help with the other values don't have those guages. These values are for pre turbo pyro and 3/4" boost plug in manifold near the fuel filter. If your locations are different, you will get different values.
