Details here: TDR Privileges
[h=3]VACUUM PUMP OUTPUT[/h][FONT="]The vacuum pump supplies necessary vacuum to components in the following systems:[/FONT]
HEVAC system
Speed Control System
[FONT="]A quick check to determine if the vacuum pump is the cause of the problem in any of these systems is to road test the vehicle and verify that all of these systems are fuctioning properly. If only one of these has a vacuum related failure, then it is likely the vacuum pump is not the cause.[/FONT] [FONT="]A standard vacuum gauge can be used to check pump output when necessary. Simply disconnect the pump supply hose and connect a vacuum gauge to the outlet port for testing purposes. With the engine running, vacuum output should be a minimum of 25 inches, depending on engine speed.[/FONT]
[h=4]DIAGNOSING LOW VACUUM OUTPUT CONDITION[/h][FONT="]If the vacuum pump is suspected of low vacuum output, check the pump and vacuum harnesses as follows:[/FONT]
Visually inspect the vacuum harness for obvious failures (i.e. disconnected, cracks, breaks etc.)
Disconnect the vacuum supply hose at the vacuum pump check valve. Connect vacuum gauge to this valve and run engine at various throttle openings. Output should be a minimum 25 inches of vacuum. If vacuum is consistently below 25 inches, the vacuum pump should be replaced. If output is within specified limits, the vacuum harness should be suspected as the cause.
Disconnect and isolate the vacuum supply harness. Cap off open ends and apply roughly 15 inches of vacuum to the harness. If the vacuum gauge does not hold its reading, then there is an open in the harness and it should be repaired or replaced.
If the vacuum loss is still not detected at this point, then the pump and harness are not the cause of the low vacuum condition. Apply vacuum to the related components of the vacuum supply system (i.e. valves, servos, solenoids, etc.) to find the source of the vacuum loss.
