What size fuel line to use when installing F.A.S.S or Fuel preperator??
Larger Than Stock Tires!?!
04.5 Intake
What size fuel line is everyone using when installing one of these system and where did you connect the fuel tank pick up line at from the pump.
I installed a FAAS system. Use the fuel line supplyed with the kit. Disconnect the stock fuel line at the tank and install the new line in it's place. You have to remove a small plastic clip on the pick up tube before the new line will connect. Every thing is supplyed with the kit. Just follow the install instructions.
TDragna
