What size/kind of floor jack do I need
Tire Question
Low power cut off devices, etc > good find
If I rotate the tires myself, what kind (or rating) floor jack should I get?
2001, 3500, 2X4, QC, SLT, Auto, 3. 54 gears, camper and tow packages. Lance model 1130 camper. Rancho 9000 5 Speed shocks. BD Brake, autoloc, pressureloc. Hadley air horns. OEM bugshield w/eyebrows and dash cover. Member San Jose Ram Runners.
I've used a 1. 5 ton jack to lift any corner of my '98 4x4. Whilst the jack works fine for changing tires, it is limited in how high it lifts (like a few inches at best). If you plan to use the jack for other under-truck work, get a jack that can lift the tire 8-10 inches off the ground. And get jack stands, as you never want to work under a vehicle that's supported solely by a lifting jack.
Fest3er
Spend some money and get a good one, 3 ton minimum. I have to use 2 cheap two ton jacks to lift the front of mine.
99 2500 QC 4X4 AUTO SB 24V LARAMIE SLT 3. 5 LSD 285-75-16'S
Get a three ton. Don't mess with anything lighter. If something slips it may bend a lighter jack. Shop around to get the highest lifting one you can find.
Joe George
Eureka, CA
'95 2500 CC auto 4X4,3. 54,Combo EGT/boost guage,custom switch panel,PacBrake,TST #5,BD valve body,Automatic motorhome steps on both sides,Foldacover hard bed cover,Cummins chrome kit,Black steel grill guard,Front hitch receiver
Costco has nice 3. 25 ton w/ foot pedal for $69 #ad
The valving works well, which seems to be the biggest difference between junk and quality...
2001 HO 6 speed Regular Cab SLT 4x4 3. 54 anti spin 2500. Used for the daily grind and sneaking away to some secret Baja beaches toting a cabover
The vehicle mechanics at work have those air powered hydraulic floor jacks. No pumping required, just push a button. Of course, theirs are huge! They lift the "pushback" tractors that push and tow MD-11's and DC-10's. Does anyone know if there is a lighter duty model of one of those available? That would be a cool thing to have in my "dream garage" someday.
Andy
Seems like I saw something similar in the Northern Tool catalog. In different sizes.
They would work either air or by hand. They have a web site. Used to be Northern Hydraulics. http://www.northerntool.com
I think.
The junker 2 ton I use is marginal and it will be replaced with a 3 ton or better. It would be nice to have a couple around anyway.
If you want a decent 3 1/2 ton jack with 2-3 ton jackstands included, that can lift up to 21 inches, check out Sears. Handy for lifting heavy Dodge trucks.
Fred Swanson
Co-Owner
Canyon State Components, LLC
www.canyonstatecomponents.com
'00 QC,SB,4x4,Auto,3. 54 w/LSD,Trailer Package, Tow Package, DTT's VB & TC
I use the 6 ton bottle jack that I carry in the bed. I also carry jack stands. Works fine for rotating, or anything else.
2001 2500; SLT; 4x4; QC; LWB; Auto; 3. 54 LS; 265s; Camper; Tow; Sliding Rear Window; Travel Convenience Group; Cab Clearance Lamps; Forest Green
Thanks for the information. I will get a 3 ton (or more) jack with the appropirate jack stands.
Here's the kind Andy is speaking of.
Shipping is free from these guys,you won't find a better deal.
"A perfect jack for industrial use--repairing trucks, trailers, buses and other heavy equipment. "
Manufacturer: Central Hydraulics
Max. saddle height: 17''
Min. saddle height: 8-7/8''
Wheel diameter: 8''; 90 to 145 PSI
Dimensions: 21-1/4"L x 12-13/16" W x 56-5/16" H
Tool weight: 112 lbs.
ITEM 39861-0VGA $349. 99
Yes, this is what I meant, but 22 tons is kind of overkill for our trucks! I was wondering if there is one like this, but is only maybe 6 or 8 tons, and at a lower price.
Andy
Andy,I've checked around and besides air powered bottle jacks that's the cheapest one I've found. There are 4 ton air powered floor jacks availible,but all of them I've seen start at around $600. Lincoln(the arc welder guys)make a full line of them,but they are pricey also.
Andy,we all knew you were a confirmed bachelor but... I could have been worse. The only advantage of air over pumping it by hand is that it will get it up faster.
Yeah, I know, but it would have been cool to have one more piece of powered equipment. I have a saying, "A man can never have too many tools, just as a woman can never have too many pairs of shoes. "
Andy
