As many know, late last year, my mistress spit her dowel pin through the case. Got all that fixed, sort of. At some point during the repairs I read that the torque value of the Fuel Pump Gear nut was to be 44lbs, so that's what I tightened it to. It's supposed to be 144lbs, I now know that and repeat it every day,
So, I took her to work the first day, ran perfect. The second day she was puffing a little white smoke at start up. I figured I probably had one set of valves a little off. She was smokin' alittle more when I left work that day. On the way home that day, traffic was really pi$$y and when I hit the freeway, I buried the go pedal. Took off like her feet were on fire and her A$$ was a catchin', until...
At 80+ the boost fell to zip and she stood on her nose. Last time I felt a truck stop like that I was in the Air Force and we hooked an F-4 drag chute to the pintle hook and we threw it out at about 95
Anyway, I backed off, and tried to find out where we were gonna stop, tried to move to the right lane, looked in the mirror and all I could see was WHITE smoke :--) . Everybody, except one broad was giving me room. I guess they were trying to figure out where and when the flames/parts were gonna go.
The idiot in question was parked at the soot pipe with her window down and the smoke was just pourin' into her window. You know how when the B-B-Q needs just a LITTLE more fluid and it smokes white until you throw the match and then KA-BOOM ! If she had lit a cigarette then, her car would've exploded!
I had the turn signal on and kept goosin' it to try and get her to move. I even hit the air horns. She finally backed off. And I shot across 3 lanes to the shoulder. Everytime I goosed it, it sounded like a AA Fueler idling :--) . Pump gear slipped
Had her towed home, found out about 144lbs and thought I put it back where I hoped it was supposed to be and tightened it to, you guessed it, 144 lbs. So now at start-up she lopes at idle for a little while, generally cleans up by the first stop sign.
Bottom line, my question is, can a 12V be timed w/out a dial indicator and what is the process? Sorry for being so long winded.
