What third gauge should I Get?
Installed 30# FP gauge, who want the 16# I had??
air lift overloads
I have a egt and boost gauge already with a autometer pilliar. Looking to add third gauge... . Should it be engine oil temp,fuel pressure or rear axle temp. . I have a manual so i dont think i need transmission temp? Am i forgetting any gauges? what gauge would you add?;) :confused: ;)
As stated above, if it's a 24v DEFINATELY fuel pressure. My recommendation is to put a fuel pressure gauge on even before an EGT or boost gauge on 24v's. JMHO
You may not think you need a temp gauge for the transmission, but I can tell you if I had one I would not have fried mine. I know I had heat build up before it let go but I had no way of knowing. Now I have a probe in the rear end, transmission, boost and pyro. I starting to believe one is needed for monitoring every device with oil and moving parts. Those units are not cheap and need looking after.
MHO.
. . Preston. .
Rcpilotlv,
I know it's been said already... but I would go with the Fuel Pressure Gauge. Sorry to be repetitive! Good luck, -Ken
