I thought that I had read somewhere that it runs on 1-3-5 for a time and then 2-4-6 for a while and alternates like this to heat uniformly? Cant remember where I had seen that so it may not be correct.
J-
The beast has a mechanical rotary pump (electronicly governed). With the way the metering solenoid works, thats physicaly possible, but I'd have to say not likely. Two plungers rotate in a 3-lobe cam ring, its easy to have the solenoid to just skip evry other event. That (yours) sounds like a good theory off the top, but I'm thinkin' that the VP/ecm arnt smart enough for that. Someone else will have to comfirm/deny for shure... .
edit=== 135/246 would have a rather rough idle and certainly un even exhaust sound. Perhaps there are different versions, but mine has a very smooth exhaust sound- even ignition- I gotta stick to the "evry other" thing.
How cold does it have to be for 3 cyl. mode to kick in? Not even sure if it's "turned on" with the mad ecm as was shipped. Anyone know?
Above temps are typical. Depends on if and how much the heaters are running, and IAT condition. Software looks for 35* for 1200rpm and 15* for 3cyl. , this is supposed to be intake temp only. I cant remember the TSB # that spells all this out, but its definately on this website in a few places.
How could you NOT tell??? :-laf:-laf Yeah, with the open exhaust, trust me
you will know.
But you have to have a smarty or other programer for the engine to run on three cylinders right? It doesn't do it if its stock?
The smarty has "latest" software version, which not only has the hi idle option, but its also automaticly turned on. My '98 didn't even have the option untill it was updated. I luckily happend across a real nice service manager while I was out of town. I stopped in to ask about this and another "quirk" I was having. Turned out he used the quirk to file a warranty claim for ECM update (possibly under EPA warranty), solved the other prolem and just "clicked on" hi idle & 3-cyl options while he was in there.
If you know some one with a smarty, have them plug in and load a smarty program, then go back to stock ecm and you'll have the new software. Save your $$ from the steeler and buy your buddy w/ smarty a case of his favorite beverage.
