Engine/Transmission (1994 - 1998) what to do..grind or buy
2nd Gen Non-Engine/Transmission Sport Bumper?
Engine/Transmission (1994 - 1998) Water pump - Napa part #?
hi all had an 03ctd,had to sell ,now i have a 97 12v
first i slid the plate. good difference, now i took it
out thinking why not go all the way. it did not seem to change
it in town doesn't even smoke ,,,how is this. .
my buddy did it to his and he said you could not even
see behind him... oh ya once o/d locks then it starts
to pull real good. . thanks to all who will write:cool:
EXSTROKER - Respectfully, you are headed on a collision course. Completely removing the fuel plate can be done, but also can quickly destroy a $2500 injector pump.
I would really encourage you to take advantage of TDR for your BOMBs.
Ask for Pros and Cons before you make the mods. I really doubt you and I could make a modification to the 12 valve that has not already been done, including screwing up our engines.
Wayne
You are local so when the pump goes and it will give me a call and I can replace it with a piers unit that will give you smoke from idle all the way up.
Bruce
I put a tracing of my plate in this thread. It worked really good and was very strong. If you wanted to try to save money and grind your own, you could copy it.
