I have a '95 (160 hp) Automatic with 145k miles. My timming is set at 15. 5 (spillport timming) and my wastegate arm has been shortened to help increase boost. I have also added a larger vibration dampner. I do a fair amount of towing (21k pounds) at altitudes between 4,800 to 10,000 feet (No. Utah and Western Wyoming). I hope I haven't forgotten anything important...
I killed the TC using my "Mystery Switch" improperly - guilty! As a reslut I'm going to get an entirely new DTT Trans (from Bill K) with the 91% TC and high performance VB. Here's the catch. Bill tells me that I'll need at least 230 hp to properly run the new low stall converter. It's doubtful whether my current setup is producing the required 230 hp.
Option A:
To accomplish this needed hp, I'm currently planning on getting a set of DD Stage 3 Injectors, 191 high flow Delivery Valves, and a 4" exhaust t to t. I'm looking at around $1,200 for just these parts - not including installation.
As I contemplate this massive undertaking, I've taken a breather to reading about Torque Plates. The more I read about them, the more I begin to wonder if a simple plate might be the answer (Option B).
Can I avoid the new Injectors, Delivery Valves, and Exhaust System and just get a different torque plate??? If so, which plate #?
What are the technical Pro's and Con's of each option - excluding cost factors? Which option will provide the best drivability, produce adequate/better hp and torque gains, and provide better EGT control? Can I get amazing low end torque and great high end performance at the same time?
I place my fragile soul at your mercy.
Thanks in advance !
- Bruce Adams
Smithfield, Utah
Option A:
Thanks in advance !
- Bruce Adams
Smithfield, Utah
