i dont want to bring my truck back to the stealer but fluid in my rear axle is low what is the best to refill with? what do they use from the factory? where can i buy this oil?
Originally posted by jlevesque
mopar does make 75w90 synthetic gl5, the part number is
5010320aa which is what you should use for top up, if you
are going to fill the fluid to the bottom of the filler hole, its best to
check it when the fluid is warm. with the fluid cold it should be
3/4 to 1 inch below.
James
