wel, since you have an auto truck there is a plate next to the master cylinder where a slave cylinder would go on a 6 speed truck. You can pop a whole in that or there is also a rubber grommet down near the brake pedal that you can go through also. As for the boost signal. You can either drill and tap the intake horn or buy a tapped intake bolt. It is a replacement bolt for the intake that is hollow and you just attach the gauge tubing to it.
