To explain my problem a bit more, the key switch kinda flops around and if I get lucky I can push the key in hard enough to engage what seems like the rest of the key switch and it would start. It is hard to get the switch to work right in any position so when i get it in the key on position I have a jumper wire from the starter that I use and keep it tied to the fender. As far as the air bag comments, i was thinking the problem was in the key switch so I thought that if the air bag was unscrewed then I would take the steering wheel off, ect. , till I got the switch out. But I will check the switch out down on the column. I assume it has a rod that goes between the lock cylinder and the ignition switch.
While I'm there, how do I check the wiring to the cruise control? The cruise hasn't worked for a long time and the air bag light has been on for the same length of time and I'm wondering if there is a connection for them inside the steering wheel. Maybe under the air bag?
Thanks
Jordan
