What turbo to use for twins on an 05 6 speed dialy driver?
05 w/ 30,000. What services do I need?
Anyone sell just the hot and cold piping for twins?
I'm about to start on a twins seup on my 2005. I am planning on using the stock 35 and HT3B/26. Is there something better? I'll be towing and driving it daily. I hope to be in the 600 hp range.
That combo is cheap to do but there are alot better combos if you wanna spend the money. I think you could go with a BD setup and have better spool and probably better cooling on top (not much but more) With the 6spd this would be a wiser choice for driveability.
Well, I have heard good things about the BD twins. But I bought a 2000 truck with them and I hated them. That truck was an automatic. Dynoed at 650hp. I was very disappointed in the BD setup. it was very hard to keep under 1300 degrees. And only 55psi. The set I built on my 2001 (HX-35/HT3B) Spooled better, ran way cooler and would peg my 60psi boost guage. It dynoed 608 hp at 42psi(couldn't get it to boost on the dyno). MAybe something was wrong with the set I had from BD. I Have heard the B1/B2 setup is awesome, but I definately can't afford those turbos.
