Originally posted by Hohn
Don't waste your money on the dd2s. Either go straight to the 3s or stick with 275s. The EZ and 275 combo is the BEST value for bombing, and you might just want to stop there. EZ and 275 gives great power, better mileage, and doesn't require a bunch of other mods to run. With this, you won't need an exhaust system ($400), clutch ($1200ish) or an intake system ($200). These are the "hidden" costs of going beyond 275s and an EZ. Stick with the 275s until you are ready to spend SERIOUS money and take the plunge. Once you DO get there, consider this:
The DD3s really don't smoke any more than the 2s. The cost-per-hp is CHEAPER with the DD3s. You can control the heat/smoke factor with your foot. The 3s are a substantial increase over the DD2s in power, but not really worse in the bad ways (smoke, heat, economy, etc. )
Clutch isn't a consideration, since you will shred it with either one
Consider this:
275 injectors= $275, 40HP.
DD2 injectors= $480, 90HP
DD3 injectors= $560, 115HP
I went with the 275s until I save the money for a clutch. Then I am going to step up to EDMs in a stage 3 or 4 after I get air and exhaust done.
Don't waste your money on the 2s unless you just want to stop right there. Have your end goal in mind.
I am going to end up with EZ, EDM 3s (or 4s), and all the other mods I need to run that much fuel (intake, clutch, exhaust, PDR40, etc). I should be able to have a lot of fun without tapping the wire.
HOHN
