While maneuvering my pickup around the other day for our pics at SOP3, I noticed my brake pedal was ROCK HARD, as if I had the key off. I thought, "Oh great, more parts I cant afford, but I have storng feet and legs, so I'll make it home, as it is 90% interstate". I got home, and replaced the booster after affirming I had sufficient vacuum (25inHg) at the hose. I even swapped a known good check valve just to be sure. Still hard. got new booster (Cardone reman; cant get Wagner or Bendix in this town). Pedal is still rock hard. What else can be causing this? I realize it is possible the reman is bad, but is there anything else?
I have relatively new (<6mo) front brake system from the hoses out, so I doubt that is the culprit, as this came on real sudden. I have done nothing to the rear- it is a 99 axle, with ~140K on what looks like original everything. Master sylinder leaks out the top gasket, and appears quite aged, possibly original.
Daniel
Daniel
