What wiper blades do you use?
Slippery rear floor.
Cfm+
i've got some 26" [stock 24" iirc] rain-x wiper blades on mine. . they seem to work pretty good. . a little expensive for what they are
The Greatest Wiper Blades!!!!!!
Sil blades!!!!!
These are the greatest blades i have ever run. i have recomended them to many and noone has complained.
i beleive there is a pretty good warrenty with them to.
Highly recomended :D
Michael
Anco. They are like $4 a blade, just even if they only last a couple years I don't freak out about buying a new set.
I have been using the rain-x blades from wal-mart for the last few years. They work great for about 6 months or so. I belive that the dry air we have here in Idaho dries the blade out quick. For the first 6 months they work absolutely great.
I use Valeo flat blades that I picked up for $7 or $8 apiece at Sam's Club.
http://www.valeowipersusa.com/index.asp?pgid=19
The only problem happens if you allow the passenger blade to drop hard on the windshield (like after you clean all the bugs off). If you do, the curve of the windshield will cause the rubber blade to "pop" out of the frame. It only does it for a couple of inches, but if you run the wipers later, that passenger blade won't work well.
Just lower it gently and all is well. In fact, at highway speeds, they work better than any blade I've ever used.
Bob
Highfinance97 said:
Sil blades!!!!!
Michael
29 bucks each! ill stick my head out the window :-laf
i use the rain x from walmart. none of the blades ive used last more that a few months so its the cheapos for me.
piaa blades
I use piaa blades. They are a bit longer than the stock and cover most of the windshield. I paid 40 bucks and worth every penny.
Bosch Icon blades, I've tried alot of others and these work great, they aren't cheap but I can see and they stay planted on the windshield at 75 mph.
Its only $money$, they'll print more :-laf
but seriously they are great blades
Michael
napa "innovision"
$18 a piece, but this is the first blade i've used that doesn't leave any streaks.
it also eliminates the need to buy a winter blade.
I agree. They aren't cheap but the are easy to install and they work better than any blade I've ever purchased. And they don't make any noise at all under any condition. I'm very impressed with them.
Bosch Icon, So far 11 months and still going, I usually change blades every 3-6 months. I was the first one on my block to have em. I do have one issue, when I use the washer squirters (with rain x bug wash) it gets into the area of the arm clip and when the blade swings back down it spits onto the windshield.
I have the same ones, work great, I like the solid design in winter with snow and slush, as the faster you go the harder they press against the window :)
