more on the stock converter
To 'the other Pau H',
You are probably correct re: Mopar being too cheap to have a conveter designed specifically for the diesel. I agree too that how you drive has a tremendous effect on not only transmission but the complete drive train. I have always tried to give the truck a break, especially when towing. When getting up to speed, I would often lock out overdrive, get up to 60 or so, let off the throttle a bit, then let it shift to overdrive and lockup before increasing the throttle again. I feel strongly that shifting with reduced power will extend the transmission and converter life. From what I understand, Banks does this automatically when you install their power upgrades.
The too cheap concept goes a bit further though. The stock transmission is marginally up to the task of putting the diesel's power to the wheels as long as everything remains stock and you are careful how you drive it. In my case, the minute I installed the RV injectors from TST, I started haveing lockup clutch slippage in the 50 - 70 mph range. Probably installing BD pressure lock and fooling the transmission into increased pressure at lower throttle possitions would have put off my problem, but I chose at that point to (hopefully) 'do it right'. I realize this is subjective, but for me, the ATS converter is the best right now. I have since installed the Edge Comp box and the new converter is absolutely rock solid! For what it's worth, I still don't let it shift with my foot in it if at all possible. Why put unnecessary strain on things - you will usually pay for it in the end.
I guess to sum it up, I would agree with you in saying common sense driving, especially when towing, will definitly extend the life of a transmission and the rest of the drive train.
Paul H
