I just went out and did the key click proceedure and here is what I get now, for codes
P0500 - P0460 - P1693
P0100 didn't come up
On the OBDII list
0500 = Vehicle Speed Sensor Malfunction
0460 = Fuel Level Sensor Circuit Malfunction
1693 = Turbo Charge Control Circuit Malfunction
The situation: I installed the CarQuest pusher pump and had all the wiring connected as per Evan's and Riflesmith's descriptions for wiring, except for the wire going to the lift pump. I unplugged the lift pump connector and was testing the wires to determine which one worked as interupted when the pump turns off (my truck doesn't have the red wire at the lift pump, that Riflesmith mentioned). That was when I noticed the engine light and the code that I first mentioned.
Before I started working on the wiring, I hot wired the pusher pump, to be sure the system functioned correctly and the truck ran. After I noticed the code and engine light, I plugged the lift pump back in and tried my test, with the hot wired pusher pump again and then the engine wouldn't start. I get 15# before and after the lift pump, with the pusher pump running and I bled the line up to the injection pump.
I'm going back out to see if maybe I knocked some wires loose. Can't imagine that, with how tight these things fit.
Doc
