I'm a Southbend fan, too. Installed many of them, including on my own trucks, and not had any problems that weren't driver related, IMO.
The 13" replacement from them is an excellent clutch. Without many power mods, they are ideal. I'd still be running my factory clutch, were it not for farm hands jerking it in gear, burning the clutch, and tearing up the Getrag... ... I used a Con-OFe in mine, and am really happy with it, and I've got quite a few mods on the truck, so it's bumping 300-350hp, I'd guess... .
The double disks are much slower to shift, mostly just due to rotational weight. If you try to hurry it up, they will grind. I'm a big fan of them for the big power numbers, but I feel they're overkill on most trucks. They engage pretty harshly, and if you're not used to driving one, you can cause some problems. If you're not really pushing the power and not trying to pull, I think a an OF or OFE are more than adequate, IMO. I like the OFE, using it in two of my personal trucks, and usually the one I recommend for customers wanting a little more out of their 2nd gens. They perform very well, and are not too harsh to shift or during initial starts. I've only used two of the OF clutches, but they seem even more smooth than the OFE, and should be as they don't have the pressure plate tension or friction resistance the OFE or DD use. A direct replacement should be comparable in cost be it a LUK, Southbend, or Saks. I like the Southbend for the service, as well, so it would be my choice.
