Sounds like you may need to crank down on the fuel crossover tubes a bit more (the 19mm nuts). Or maybe the tip of the crossover tube may have been nicked during the install (not popping the tube out the side when removing/inserting the injectors). Either way it sounds like you're getting a bit of air in the lines.
The injectors are sealed at the bottom from the cylinder by the copper crush washer and at the top from the engine oil by an o-ring. Any fuel leaks would occur in the middle where the crossover tube hits the injector body, and the fuel that had leaked out will flow out the back of the head into the fuel return line to the fuel tank. Therefore, fuel will never mingle with the oil (that's a Ford/Chevy issue; when they leak, they just leak into the engine oil). You may see some fuel weeping around the 19mm fuel line nuts, but you might not see any leaks at all if they stay in the fuel return passage.
When you say that you had nothing but problems, what troubles did you have?
