Originally posted by Power Wagon
I put a set of 215 nozzles into a set of 1st gen bodies. It requires you change the spring, spring seat, and intermediate plate, to do it. And of course, you have to set all the pressures with new shim packs... I took a set of takeout 2nd gen injectors apart and put thier guts into a set of earlier bodies to make it work.
Our best evaluation is that there is a small loss of power over stock injectors in a '92 engine. Ergo, this is not really a performance swap. HOWEVER, if you were running consistently at very high altitude (say, over 6000), I would consider using these plus a 12CM wastegated turbo, to cut down the smoke. With thier 6 fine holes and a moderate fuel amount, it should be about the cleanest thing you can do.
