I personally do radiator flush, thermostat, water pump, ALL my fluids and seals front to back top to bottom (4x4 if you have it), all my filters (depending on how often you normally change them), and injectors. Myself and a couple of my buddies do ALL this every 100K if it needs it or not. I believe there may be something with the EGR on the 6.7... not 100% hopefully someone with a 6.7 can chime in on that part. Normally all this will cost a couple K at a shop but you can save a lot if you have the time and know how to do all of it. Hope this helps! Good luck.
