I finally went and bought a fuel pressure gauge set. I got the electric with two senders, one for pre filter, one post filter. I installed a switch, so I can gauge the drop across the fuel filter.
Here's the problem. I'm idling at 36PSI fuel pressure. From what I've seen, this is abnormally high... . isnt it?
I mashed the engine, and couldnt get it to go below 25. This is just around town, on the open road I'm certain it will go lower.
I do have a snubber hooked up, and I will have to verify this with a mechanical gauge (glad I put a tee in the setup now!!!) but both senders are within one PSI of each other, so I got to believe it's reasonably accurate.
What is actually considered a normal reading?
Eric
Eric
