My daughter has a 96 CTD which wouldn't start this morning. She hadn't started it in two days and I'm curious to know what part/systems have power available when the ignition is off and the key is removed. I know the lights, door locks and cigar lighters all have power but is there something else?
When I checked the truck the batteries were both essentially dead (less then 8 volts) and both seemed to have the same amount of charge (i. e. neither one was totally dead as in shorted).
She's is sure her lights weren't left on and she had the batteries checked a couple of months ago but doesn't know how much water is in the batteries (I didn't check because a) it is cold out and b) it is dark out.
Once we got the truck started everything seemed OK voltage indicated a charge state, lights were as bright as normal, and after idling for a bit the voltage dropped some (to about 14 volts) to show the batteries were charging some.
