What do you guys think this may be?
When driving on the highway or really any speed, that diesel chatter gets louder when the engine is not under strain or not slowing down. When maintaining a steady level speed, the chatter (the sound from all diesels) gets a little louder.
I just starting noticing it a couple weeks ago. No loss in power, no extra smoke, no missing or anything I can tell. At first I thought it was the transmission but it does it in every gear and any speed.
Now I think it may be an engine issue. I don't know what happens when injectors go bad, or if the valves need adjusting.
I just found a water leak and I think it is the water pump. I don't think that would make the noise. Only added about 1/2 gal of water if that much.
The noise is the same noise all diesels make, it just gets a little louder when cruising, any ideas? am I in danger here????
What do you guys think?
Thanks
Thanks
