Whats THAT Noise???????
Axle Seal Leak
Throttle sticks
I was driving my truck up the Grapevine I-5 loaded with firewood, the hill is steep. I proceded to throttle up (75 MPH)and was running hard for couple of minutes when this "death rattle" burst from under the hood. Only thing I can say it sounded like is rod bearing the instant before it blows. I lifted off the throttle and the noise went away. I moderated the throttle, since then I have run the truck hard but not with a load on a grade where sustained high output was possible. The reason I present this topic is that Grsjms a fellow TDR member related a similar problem but in his it is repeatable.
I know there are some real Cummins thinkers so pony up. What was it?
2001. 5 2500 ETH/DEE 4x4,Patriot Blue over Silver,Camper pkg, Trailerpkg,3. 54LSD, Agate Leather,Stainless Smitty Bars,Tow hooks,Amsoil,Window Fix... ... ... :) Except snowplow!
My guess its the cooling fan. When that mother engages it makes alot of noise.
Grapevine is a nice pull which will engage the fan easily #ad
My truck did the exact same thing when I was towing through New Mexico up some very long grades in 5th gear about 2600 RPM's.
When I got off the gas, the really noisy sound went away. I think it was the radiator
fan engaging.
Charles
2000 QC 2500 4x4 LWB ETC/DEE, Anti-Spin, 3. 54, Trailer Tow, Camper Special, DD1's, PS boost module, PS high idle kit, PS steel idler pulley, Autometer boost and EGT gauges, Westin nerf bars, Rhino Liner
My Toy
1969 Toyota Land Cruiser FJ40
350 TBI, Turbo 400, ARB lockers front/rear, 4 wheel power disk brakes, 4. 88 ring/pinion, 3 speed transfer case, full roll cage, Warn 8274, MRT 36 bolt beadlocks with Super Swamper Boggers (16x35x15), Saginaw Power steering, custom bumpers/fenders/nerf bars/skid plate, GM tilt steering column, 6 point roll cage, RCI racing seats with 5 point harness. Conquered Tellico and going to Moab this May. Loves to be pulled behind the Dodge and pass the powerjokes going up hills.
I'd be willing to bet that it was the cooling fan. The first time mine came on, climbing the Continental Divide @ 75 MPH, I almost had a heart attack. Loud as hell, pretty scary. Now I just try and keep things from getting so hot so I can hear my turbo more clearly.
2000 3500 QC 4x4, 6 Speed, 4:10, LSD, Raider cap, Carpet kit, Spray-in liner, K&N Filter. "OBNOXIOUS BEAST"
Well sounds like the fan was the culprit. Wow, it's really loud then? I will push it harder this summer. We have a trip planned to the North rim of the Grand Canyon with stops at Lake Powell and Yellowstone. That will heat her up for sure!
Jnutter: No gauges yet, I was curious about the 3 gauge pillar mount with the dual function SPA gauges. EGT Inlet/Outlet of turbo, Boost/Fuel pressure, Voltmeter/Ammeter. I don't know if these combinations are available but seems to me this would be the best combination.
Thanks Again, Rich
Definately NOT the cooling fan. Sounds mechanical, sorta reminds me of valve or lifter float. Truck is stock so temps not available. Happens everytime on WOT @ 2000RPM or higher.
2001. 5 SLT QC SB 4X4, 6 speed, HO, LSD, 241HD, 3. 54, camper special, power everything, trip thingy, REAL bumpers, green/silver, Nerf Bars, Vent Visors, trailer tow pkg
Mine runs all the time. Sounds like a blower is under the hood... or a high speed wind tunnel...
2001. 5 QC 2500 White Sport 4x4 LWB ETC 5-Speed Anti-Spin 3. 54 Trailer Tow 241HD SLT+ Tan Leather(Mad Cow Disease) LT265/75R16E ARE Z Series Cap Bedrug ICI Nerfbars
[This message has been edited by Smokin Joe (edited 05-17-2001). ]
