Engine/Transmission (1994 - 1998) Whats the best delivery valve
I see some places have the 191s, then thell have high flow and super high flow then you have lazer cut. Whats the differance and how much more cc of fuel will you get. Thanks
ive been curious about the same thing what is the difference in cc's. im currently running 191's but debating on going to laser cuts. thanks
I don't know the cc's difference but the flow difference is quite a bit. Most people on here add DV's but what they really need is more injector..... FYI!
Jim
Jim, why do people install monster Laser Cuts when you can make such big power on even 181s? I'd think even 191s are rarely necessary.
Educate this ignorant 24Ver.
jh
There cheap, easy to install and and cheat and injector on it's size to a point. They have there place, especially in smaller pumps.
Jim
Jim
I have to agree there, my 175 pump is much more well mannered with the 191's vs. the 131's running the marine injectors
That's allot of smoke. I remember when I had smoke like that before it started cleaning up. Dan wants me to try some of those DV's to see if i can get the . 093 lines to work better on the dyno. Now all I have to do is come up with some cores to send to him... ... hate the cut my 2 sets up!
Jim
Jim Fulmer said:
I'm going to guess and say EGT's were at 2 grand... ... . that truck needs water..... bad!
Jim
Pretty sure the pyro pegged, it was easy to do with that setup. : :-laf
Sled Puller 66 & DDP Stage 4s work nicer than my HX35 & Laser Cut DV's Oo. as far as temps go (well, power too!!) :-laf
My last test on DV's was as follows: 181's... . 816 hp. 022's... . 848hp... . both on #2 only. Correction factor was . 99
On Bobcats truck there is no doubt that he'll make allot more power with his DV change, it's fuel all you have to do is burn it.
Jim
