What's the best power steering set-up?
1996 Dodge 2500 V8 to Cummins
85 Crewcab Conversion
I think that I've decided to remove the bendix compressor therefore the vickers pump will probably go also. It's on chevy K3500 with hydro boost. What's the best pump and easiest way to get it done. it's a 1st gen motor.
Whats the best powersteering setup
As i said in the e-mail to you use the dodge setup its cheap and easier and
there is no hassels
In my chevy crew cab I used the original steering box and hydroboost with a dodge pump works great. Ive put about 10k miles on it and have had no issues. I am however going to add a cooler in the return line to help keep the fluid a little cooler figured it couldnt hurt. If you need any more info just let me know and I will try to help.
